Getting lift in one corner of prints
william.g19
(@william-g19)
I've been having good success for smaller prints, but when I do larger prints I am having a problem with one of the corners not sticking and pulling up after a number of layers. It also looks like that corner is being rushed, as even during the skirt printing it "cuts the corner".
Any ideas on how to fix?
Edit: Added image:
Thanks, Bill
Prusa MK2S kit
Respondido : 18/12/2017 9:49 pm
william.g19
(@william-g19)
Re: Getting lift in one corner of prints
(I just realized this is in the wrong forum... I don't see how to move it but I would be happy to have it moved.)
Respondido : 18/12/2017 9:58 pm
BillC
(@billc)
Bill,
Have you run hyperfine bed calibration?
If the skirt is not sticking but getting dragged round and cutting the corner this usually means the nozzle is not close enough to the bed at that point. If you have run hyperfine with good results then try moving the print over on the platen before you slice it. That may be enough to save your print.
Bill
Tagaytay City, Philippines
Respondido : 19/12/2017 3:35 pm
william.g19
(@william-g19)
Thanks, good suggestion I will give this a try.
In terms of the curl I saw another thread and printed out the part and this seems to be doing the trick.
https://shop.prusa3d.com/forum/print-tips-slic3r-settings-kisslicer-model-repair--f12/left-side-of-print-is-curling-up-during-print-t12403.html
I still like the idea of the hyperfine bed calibration though so I think I will do that as well.
Thanks again!
Respondido : 20/12/2017 2:14 am
