Fuse F3 blown on first preheat
fluxpenguin
(@fluxpenguin)
So after nearly a week of assembly and adjustments I finally managed to get my i3 MK2 assembled:
- Selftest OK.
- Calibrate XYZ: OK - axes are perpendicular 😀
So I went to insert the filament but I was seeing "ERR: MINTEMP BED" as it was only 11 degrees C in the garage,
After applying some heat with a heat gun to get to > 15 degrees and power cycling the machine I went to "Preheat" selected PLA and then....
Everything shut down.
Having pulled the fuses it looks like F3 has blown 🙁
Does anybody have an idea whether this could be a wiring issue, bad luck or cold weather (or all 3)?
Respondido : 12/02/2017 2:23 am
david.b14
(@david-b14)
Re: Fuse F3 blown on first preheat
I had this issue with my other 3D printer. To fix the issue both by Mk2 and other printer are under a $6 Bella plastic storage container.
I heat the air in the enclosure using a $12 space heater, one with the knob thermostat built in.
Respondido : 12/02/2017 4:29 am
JeffJordan
(@jeffjordan)
Miembro Moderator
💡 might be either bad luck or a wiring issue with the heatbed (don't think it's weather related).
❓ did you replace the fuse (15A, i think a car fuse will do) ?
➡ can you measure the resistance of the bed ? should be at about 1 ohm (+/- 0.2 ohm).
:mrgreen: or maybe somebody assembled the c54 in the wrong direction, which will blow up that capacitor with an intensive smell like rotten fish :mrgreen:
Respondido : 12/02/2017 6:27 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Check the PSU is set to the correct voltage.
Check that the power inputs are in the correct sockets - it has been known for users to plug the power inputs into the bed/extruder heater outputs and heater plugs into the power inputs.
Check that there are no shorts on the bed cables.
The self test should heat the bed a little, so it may be that you only need to swap the 15Amp fuse.
Peter
Respondido : 13/02/2017 12:16 pm
christopher.d3
(@christopher-d3)
I suspect I've also blown the fuse, but I haven't come across this kind of fused socket before. How do I open it to get at the fuse without breaking it? Thanks. 😳
Respondido : 15/02/2017 5:24 pm
JeffJordan
(@jeffjordan)
Miembro Moderator
💡 there's nothing to open. just pull the blue 15A fuse (the whole thing with the blue plastic) out of it's socket and replace it with a new one.
➡ you can get these kind of fuses at every well sorted car shop (or even at your petrol filling station).
Respondido : 16/02/2017 12:11 am
