First prints and questions
ed973
(@ed973)
Assembled the kit, calibrated and did some small prints thats to me looks good:
First question, is normal that the printer during calibration process leave behind small filaments blocks:
Second, now I have some issues printing long parts:
As you can see the right corner is lower than the left and is also messy:
Do I need a new calibration?
Thanks in advance for help.
Napsal : 29/08/2017 2:25 pm
AJS
 AJS
(@ajs)
Re: First prints and questions
First question:
original-prusa-i3-mk2-f23/material-just ... tml#p38004
prusa-i3-kit-building-calibrating-first ... tml#p33349
original-prusa-i3-mk2-f23/dealing-with- ... t5582.html
Second question:
That certainly means something is wrong. Are your axes perpendicular?
Napsal : 29/08/2017 2:44 pm
ed973
(@ed973)
Thanks for your reply.
Can you edit linked posts?
Will check machine perpendicularity?
Napsal : 29/08/2017 7:09 pm
john.f14
(@john-f14)
Re: the first question and his links, I just asked the same here http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/extruder-dribble-t5685.html
Basically "it's normal", the first link has a gcode strategy to mitigate it.
Napsal : 29/08/2017 7:24 pm
AJS
 AJS
(@ajs)
http://shop.prusa3d.com/forum/original-prusa-i3-mk2-f23/material-just-flows-from-nozzle--t5282.html#p38004
http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/filament-leaking-from-nozzle-during-heating-t4494.html#p33349
http://shop.prusa3d.com/forum/original-prusa-i3-mk2-f23/dealing-with-ooze-during-mesh-bed-leveling--t5582.html
Sorry. Not sure why those edited that way.
http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/extruder-dribble-t5685.html#p40365
Napsal : 30/08/2017 1:58 am
