First Print
robert.c
(@robert-c)
First Print
i Just started the first print, it's the prusa logo i suppose. The rear fan doesn't start, is it correct?
Btw, amazing!!!! =)
Respondido : 24/12/2015 6:01 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: First Print
Robert
The rear part fan is not used when printing with ABs.
Peter
Respondido : 24/12/2015 6:03 pm
robert.c
(@robert-c)
Re: First Print
Ok, perfect.
I think i will change the washers of the heating bed with some plastic ones because there's a short circuit if they are too tight to the bed circuit board.
Respondido : 24/12/2015 6:13 pm
PJR
 PJR
(@pjr)
Re: First Print
Robert
Washers are stamped out of a sheet of steel and have sharp edges on one side and smooth edges on the other. Just ensure that the smooth edges are facing the heated bed.
Another solution is to change the heater polarity - swap over the wires in the screw connectors.
If you do decide to use an insulating washer, then please bare in mind that the bed reaches temperatures in excess of 100 degrees Celcius.
Peter
Respondido : 24/12/2015 6:32 pm
robert.c
(@robert-c)
Re: First Print
Great hints,
thank you Peter. I will try facing the washes as you suggested!
R*
Respondido : 24/12/2015 6:52 pm
