First Print. Think it came out good
Archania
(@archania)
Hi all.
Well I thank all of you for all the information and past issues you all had! Lol
When trying to preheat the bed, it was tripping and restarting the machine. Quick search gave me the answer of one of the washers faulted it. Took it off (after leveling it before) added some electrical tape to the washers for a buffer. Leveled it again and no issues!
Think I need to adjust the bed height to the nozzle though. Did the card test and thought I got it correct (much different then adjusting CNC bits that is for sure!)
I took pics of the print and the settings screen as it was running.
Any thoughts or is it good to go? Always looking to improve to get some sweet prints out.
Thanks all!
Opublikowany : 24/12/2015 12:46 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: First Print. Think it came out good
Hi Scott
Congrats on your first print!
The part seems to have stuck well ans is quite clearly defined, so the best thing to do now is to run of a few prints of your own and make sure you are happy with them.
That's all that matters really; that you are happy. Of course there are ways to improve the prints. Every printer is different, so they all have slightly different flow rates for example. This is one easy tweak to make - see attached document.
Also don't forget that this printer is not expensive; it produces results better than much more costly printers, but it can be modified with a variety of upgrades to generate even better quality prints. However, its about bangs per buck and depends on the depth of your pockets!
Have fun printing and learning. You will soon find out where you want to go with this.
Peter
Opublikowany : 24/12/2015 11:00 am
Archania
(@archania)
Peter. Thank you very much. I was playing with leveling the bed a lot. To me it seems that the front is ever so slightly lower then the back but from what I have printed so far (test block from another site) the layering seems really good.
Printed the tree frog out last night before bed too lol. Any ideas on the little gap there on it's back?
Just getting the prints off the glass seems to be my biggest issue. They just stick so darn well. lol
Will be printing your attachment after work today. Thank you.
My son already grabbed a simple design from Maya to try out while I'm at work (lucky kid!)
Thanks and have a great holiday!
(Already have several different colors of PLA listed on my wish list! and was looking at a different bed instead of the glass - woot more money to spend!)
Opublikowany : 24/12/2015 12:00 pm
PJR
 PJR
(@pjr)
Scott
Stick with the glass bed at the moment. Put it in the freezer and the prints will release a lot easier. Get a second glass sheet so you can print on one whilst the other is cooling.
That small gap on the back - what filament are you using? If it's ABS, then it could be because of a draft. Otherwise, it may be temperature, calibration, bed level, print speed, in fact a whole load of things.
For PLA, I have blue painter's tape over the glass. This helps with bed levelling as well - wrap the ends of the tape over to the other side of the glass, so that the tape is between glass and heater.
Peter
Opublikowany : 24/12/2015 12:59 pm
Archania
(@archania)
Peter. Thanks.
Do you run heat with the blue tape? I have some just haven't used it yet.
Thank you again for all the help.
It is the grey pla from here BTW.
The settings are the default 210/50 for the temps. Pretty good on the leveling that I can tell with the card. But will check again. Plus the machine is leveled on the table.
Opublikowany : 24/12/2015 1:12 pm
PJR
 PJR
(@pjr)
Scott
210 is the upper end of PLA temps; you could drop that by 10 degrees.
With blue tape I use between 40 and 60 degrees depending on size of print; however if you bet the first layer squished down, there is probably no need for any heat; it does stick very well.
OK, if the frog was printed with PLA, then it's possibly a feed issue (tweak - increase by 3 or 4%) or you may need an additional perimeter(loop) - (3 rather than 2.
These things are all trial and error.
Peter
Opublikowany : 24/12/2015 1:20 pm
Archania
(@archania)
Cool. Will try that after work today.
Thanks again.
Opublikowany : 24/12/2015 1:22 pm
PJR
 PJR
(@pjr)
Scott
One other thought for you.
You probably know that PLA soaks in moisture from the air and degrades quite quickly, such that printing with it becomes difficult.
I find it best to use whole spools of filament and not leave any laying around for too long.
So, I buy mainly white filament. When I want different colours, I have an airbrush and a wife who is quite arty. That way, you get any colour(s) you want, without having too much stock of PLA.
Peter
Opublikowany : 24/12/2015 1:29 pm
Archania
(@archania)
Lol very nice.
Opublikowany : 24/12/2015 1:40 pm
Archania
(@archania)
Hi all and Merry Christmas/Happy Holidays!
I tested and printed some other items and all were good.
I decided to print one of the tiles - Wall B from Fat Dragon 3D Tiles.
All was going good. It was very late and i went to bed. I got up to a completed wall. Cleaned it up and noticed that it shifted in the X after the second set of the wall. Base came out wonderful and the piece stuck to the glass fantasticly.
Used Slic3r to get the gcode using his original 1.75 PLA settings. All looks good in the Slic3r from what I can tell.
Any ideas? Cause the rest printed great after the initial move. Now the print head shifted over. The piece was still firmly stuck to the bed. So this is confusing me a bit.
Opublikowany : 25/12/2015 10:59 am
PJR
 PJR
(@pjr)
Hi Scott
I am experiencing the same issue. See here: http://shop.prusa3d.com/forum/viewtopic.php?f=6&t=405&p=2823#p2823
As soon as I get to the bottom of this, I will let you know.
Peter
Opublikowany : 26/12/2015 12:26 am
