[Zamknięte] Fire hazard
Strona 1 / 2
marten.g
(@marten-g)
Fire hazard
http://wiki.e3d-online.com/wiki/E3D-v6_Assembly
Like all 3D printers, printers fitted with a high temperature all metal hotend can be a fire hazard. You are using experimental technology to heat and melt plastic, in a machine that you may have built or modified yourself, that likely does not have safety certification or significant failsafes. Fire/Smoke alarms, supervision of your printer while printing, and expertise should not be considered optional.
What is the worst case scenario?
Opublikowany : 16/10/2016 8:37 pm
simon.p
(@simon-p)
Re: Fire hazard
Dead people I suppose.
Opublikowany : 16/10/2016 9:27 pm
marten.g
(@marten-g)
Re: Fire hazard
Thanks Simon 🙂
But I want to know how people die because of a 3D printer.
A malfunctioning fan is bad. What happens when the fan dies?
Opublikowany : 16/10/2016 10:08 pm
simon.p
(@simon-p)
Re: Fire hazard
The extruder fan? Idk. Probably a clogging extruder at some point. Not sure what happens though if the extruder temperature is set to its software/firmware max...which I don't know right now. The carriage could lose its integrity at some point without a working extruder fan.
Opublikowany : 16/10/2016 10:18 pm
David T.
(@david-t)
Re: Fire hazard
3D printer is as dangerous as any other device using electricity for direct heating. If something goes very very very wrong, it can catch fire. Then people can die.
I know about few cases when hardware failure caused damage to 3D printer, fortunately none of them was with fire.
I never let my printers work unattended. Room with 3D printer is equipped with smoke detector and there is always somebody at home when one of printers is working. Better safe than sorry.
Opublikowany : 16/10/2016 11:05 pm
simon.p
(@simon-p)
Re: Fire hazard
To add to this. If I remember correctly I read on this forum that the heater cartridge is not powerful enough (at 12V) to melt the aluminium of the heater block.
Opublikowany : 17/10/2016 1:33 am
Nigel
(@nigel)
Re: Fire hazard
Serious enough for me to have a smoke detector/ fire alarm in my 3D printer room, and never leave home with a 3D print running. PLA can burn like a candle. Light the end of some PLA filament with a lighter and see. However the likelyhood of a fire like this with any 3D printer is rare. Lets just be careful out there 🙂 That is all.
Nigel
Opublikowany : 17/10/2016 3:42 am
miferr
(@miferr)
Re: Fire hazard
I'm interested in hearing how people handle long prints. I recently did a 39-hour print. There's no way I could have done that without going to sleep or leaving the house.
Opublikowany : 17/10/2016 4:29 pm
David T.
(@david-t)
Re: Fire hazard
http://www.safelincs.co.uk/fireblitz-automatic-fe36-fire-extinguisher/ 🙂 (Trying to lighten this topic a bit)
Opublikowany : 17/10/2016 5:50 pm
stevQ
(@stevq)
Re: Fire hazard
I really thought about something like that. I'm not sure of the implementation yet.
A Box with this on top was my idea. But I'm not sure how good the tolerance are for the system. 79°C is high, but I'm not convinced it's high enough.
What do you think?
Opublikowany : 17/10/2016 7:15 pm
David T.
(@david-t)
Re: Fire hazard
Use this inside printer box:
Opublikowany : 17/10/2016 7:51 pm
jan.p18
(@jan-p18)
Re: Fire hazard
Yes, that's it. And at least 4 times a year whole family fire drill. Children can be trained 12 times a year.
Opublikowany : 17/10/2016 8:28 pm
marten.g
(@marten-g)
Re: Fire hazard
Thanks for all useful information. Larger nozzle for shorter prints, mine is 60 hours with 0.4 mm nozzle. Fire alarm in printer room. In future build printer box with automatic fire extinguisher.
How flammable are different filaments? I am using PET but contemplate using ABS
Opublikowany : 17/10/2016 9:21 pm
David T.
(@david-t)
Re: Fire hazard
ABS is quite flammable. However it needs to melt and boil first. Its autoignition temperature is about 460°C.
Opublikowany : 17/10/2016 9:52 pm
miferr
(@miferr)
Re: Fire hazard
Going back to the OP quote:
So what failsafes are actually in the printer? I only know of the Thermal Runaway error, which I believe is in case of a thermistor failure.
I found this video, which looks really promising:
I also found this video, which tells me I'm not dressing the part:
Opublikowany : 18/10/2016 12:38 am
David T.
(@david-t)
Re: Fire hazard
Software failsafe - thermal runaway protection and temperature limits.
Hardware failsafe - fuses protecting against high currents (short circuits).
BTW I would never rely only on failsafes provided by printer itself. CPU may hang leaving the board with heaters permanently on. Failsafes (if used) should work independently.
Opublikowany : 18/10/2016 9:39 am
miferr
(@miferr)
Re: Fire hazard
My nephew is an electrical engineering student and said he'd help me figure out how to implement the device in this video. He picked out a relay that he thought would be adequate, but he said to know for sure I would need to know how much current the printer draws. Anyone have an idea? I promise I'll post some pictures with the results. 🙂
Opublikowany : 19/10/2016 5:29 am
David T.
(@david-t)
Re: Fire hazard
What current are you asking about? Input current to PSU (120/230V)? Output current from PSU (12V)?
Opublikowany : 19/10/2016 8:32 am
MrMik
(@mrmik)
Re: Fire hazard
I don't know how unlikely it is but here goes:
The hot-end somehow sets the extruder body (? PLA or ABS?) on fire.
The flame wicks up the filament until it reaches the full 1kg roll of filament above it.
The filament roll catches fire, starts to drip onto the printer and run over the edge of the printer and the table onto the carpeted floor, and towards the wallpaper, bookshelves or curtains.
The rest of the house follows. 😮
Opublikowany : 19/10/2016 9:12 am
miferr
(@miferr)
Re: Fire hazard
I believe he was talking about putting the relay between the outlet and the printer, so it would be input to PSU. Here is a possible relay he mentioned that he believes would be adequate: https://www.adafruit.com/products/3191 because it can handle "up to 10A of resistive-load current at 120VAC".
Opublikowany : 19/10/2016 2:37 pm
Strona 1 / 2
