        Filament holders won't fit?
I just got my pre-assembled Prusa mk2, however the filament arms don't attach to the top frame! There's very little mention of how to attach the things anyway, but I watched a few videos and I can clearly see how they are supposed to attach. But it seems opening on the holder arms that go onto the main machine's frame are *slightly* too small. I've tried forcing them on at this point... no dice.
                            Napsal : 05/04/2017 4:06 am
                    Re: Filament holders won't fit?
dont force em, they will break as i found out, you may need to just sand/ file a bit on the top of the arm to get it to fit, go slow as too much taken off leaves it loose. should be a case of push down and slide under the frame
                            Napsal : 05/04/2017 4:14 am
                    Topic starter
 answered:
Ah, thank you. I figured that's what I should do - got it fitted perfectly now.
                            Napsal : 05/04/2017 4:45 am
