Filament Cleaner / Oiler - Is it needed?
Webdad
(@webdad)
Been running my Original Prusa i3 for about 4 months. Haven't had any issues with clogging or blockages. I keep all my filament (majority PLA) in Samla boxes with silica gel boxes to keep them dry.
I've seen a number of filament cleaners with sponges and recommendations for using various oils to clean / lubricate filament on the way to the printer.
I was wondering if that is really necessary or if it is something I should consider doing in the future?
Seems the lubricate is mostly focused on making Bowden feeders flow better, but wanted to see if anyone has any experience or recommendations.
Thanks.
Opublikowany : 21/07/2016 3:17 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Filament Cleaner / Oiler - Is it needed?
Ray
I have see these in use with other printers, but I have no need to install any such device on the Mk1 or Mk2.. My printers are running 24/7 are are producing exceedingly good prints continuously - the only time I have a problem is when I make a mistake...
To assist with the filament feed, I did include roller bearings on the spool holders, although it was working fine before.
Peter
Opublikowany : 21/07/2016 3:38 pm
Nigel
(@nigel)
No.
Nigel
Opublikowany : 22/07/2016 3:21 am
