Fan noisy when turns on
wless1
(@wless1)
Hey all,
I have have an MK3 built from a kit, and I noticed recently the print cooling fan making quite a bit of noise when it initial turns on after the first later. After running for a tiny bit of time, it quiets down. Is this normal?
Thanks!
Veröffentlicht : 01/03/2018 5:37 pm
Nikolai
(@nikolai)
Re: Fan noisy when turns on
Happens on my MK2 on the part cooling fan sometimes as-well. No worries, after couple of seconds it goes away once the rotating parts are lubricated again.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Veröffentlicht : 01/03/2018 7:19 pm
I believe these are plain bearing fans,
I have re lubricated the bearing on my mk2, but eventually replaced it with a ball bearing fan instead.
Mk3 is running fine at the moment... may get a ball bearing fan in stock, for when it fails.
regards joan
Veröffentlicht : 02/03/2018 12:05 am
wless1
(@wless1)
Thanks for the replies!
What type of lubricant is necessary, and what's the steps to lubricate the fan?
Veröffentlicht : 02/03/2018 12:26 am
