"falling down" support material
Hi all guys,yesterday i try to slice Marvin (stl downloaded from 3dhub) using the Detail .25mm nozzle preset in slic3r,the only option i have change is "with sheath around the" to see what happen when the support will be print attached to the heat bed.
then.....i have a problem with that,because before a total 5mm heigh was reached the support fall down.....i have try to use a higher brim option to bond the support to the base,they don't fall down but is hard to remove it.
have you any idea how to fix it?
thank you.
D
From Florence with Rage!!!!!
Re: "falling down" support material
Well, the 0.25 nozzle preset is for 0.25mm nozzles. The Mk2 is shipped with a 0.4mm nozzle so maybe you are trying to significantly under-extrude?
When using supports, Z-lift may help.
Peter
I have the .25 nozzle mount on printer,i forgot to say it,pardon me 🙂
Using a 4mm brim to attach the support to the model and all together to the bed i have resolv this issue,but my support stil have some problem (i attach 2 photo),any idea?
And about the printed quality,how can i try to improve?
(Printed in layer of .05 ).
Thank you
