Extrusion problem
alexander.g
(@alexander-g)
Extrusion problem
I've been happily printing for the past few months. Lately, I've hit a problem, which I think is caused by not enough filament getting extruded. The end result is separated threads on the resulting print.
[attachment=0]IMG_1633[1].JPG[/attachment]
Bringing the temperature up (PLA, from 210C to 240C) and increasing the flow to 130% helps a bit, but not too much.
I changed the nozzle with a brand new one, but the problem persists. I noticed that when changing filaments, there is an edge in the retracted filament, so I suspect there is some clog in the extruder body. Any tips on how to solve this?
[attachment=1]IMG_1632[1].JPG[/attachment]
Respondido : 24/01/2016 5:42 pm
Josef Průša
(@josef-prusa)
Miembro Admin
Re: Extrusion problem
Maybe the PTFE tube wore down. You can check this guide we made. http://manual.prusa3d.com/Guide/How+to+replace+PTFE+tube/82
Instead of completely replacing the tube you can just push it a little bit deeper and cut the degraded end.
Founder and owner / Majitel a zakladatel
Respondido : 24/01/2016 8:07 pm
alexander.g
(@alexander-g)
That appears to have solved it, thanks! Step by step guide was very thorough.
Respondido : 07/02/2016 2:09 pm
