Extruder working before printing but stops
Jane doe
(@jane-doe)
Have built the kit and the fan is connected correctly as it kicks in at 50 degrees, also i can get load the filament and extrude some under the settings menu but when i goto print nothing comes out and the motor that drives the extruder chews out the filament?
Where to start looking for the fault?
Napsal : 18/09/2015 2:23 am
Josef Průša
(@josef-prusa)
Member Admin
Re: Extruder working before printing but stops
Are you sure you are not trying to print a g-code for 3mm version? LCD info screen would show 285C 💡
Founder and owner / Majitel a zakladatel
Napsal : 18/09/2015 11:12 pm
Jane doe
(@jane-doe)
Calibrated the bed when it was cold, rookie mistake.
Napsal : 24/10/2015 6:50 am
