Extruder Voltage Problem
dave.d2
(@dave-d2)
I have a 12" Prusa i3v.
All set up, calibrated, axis all homing and working.
Try my first print and the extruder won't fully heat up.
12 volts at source input.
5 ohms on extruder heater.
Only 5 volts on Extruder mosfet output.
What is configured wrong ?
RAMBo board with Marlin software.
Veröffentlicht : 19/07/2016 6:11 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Extruder Voltage Problem
Hi Dave
I don't know who makes a 12" i3v printer; certainly not Prusa Research - the largest made by this company is 250 x 210 x200 mm.
Can I suggest that you contact the manufacturer of your printer as this forum is for users of the PR "original" i3 and i3 Mk2.
Peter
Veröffentlicht : 19/07/2016 11:15 pm
dave.d2
(@dave-d2)
Ignoring the first part of my message (it's an open source chassis but the guts are Prusa)
The problem is as follows:
Trying my first print and the extruder won't fully heat up.
Veröffentlicht : 20/07/2016 3:43 am
PJR
 PJR
(@pjr)
Dave
What firmware version are you running?
Peter
Veröffentlicht : 20/07/2016 9:21 am
PJR
 PJR
(@pjr)
Dave
Thinking about your problem, it seems as though you have only 5V on the 12V rail (or the output is being PWM regulated to 5V which is highly unlikely, unless the firmware is wrong).
As the extruder heater is run from the same fuse as the electronics, the fuse and power feed should be OK, so back to the firmware. could be using a wrong pinout?
The only other possibility that I can think of right now is that the RAMBo has a problem.
So, which firmware version are you running?
Peter
Veröffentlicht : 20/07/2016 11:37 am
PJR
 PJR
(@pjr)
Just had a look at the RAMBo schematic. It would appear that the two 12V inputs are isolated, so although the steppers and controller will run when powered via a 5V supply, the extruder will display exactly what you are seeing. Can you therefore check to ensure that both 12V rails from the PSU are supplying 12 V and not 12 V + 5 V.
Peter
Veröffentlicht : 20/07/2016 2:57 pm
dave.d2
(@dave-d2)
I confirmed that all 3 input rails are at 12volts.
I used Arduino 1.6.5 to install Marlin_RAMBo_1-1b_GLCD
I have tried other combinations of Marlin with RAMBo-master but none of them seem to install anything that displays on the LCD.
Veröffentlicht : 20/07/2016 3:21 pm
richard.l
(@richard-l)
Mitglied Moderator
The firmware that you have mentioned is for the Lulzbot TAZ2. If this is an Original Prusa it will be using the Rambo Mini.
Veröffentlicht : 20/07/2016 4:14 pm
PJR
 PJR
(@pjr)
This is a full RAMBo board (or a clone); not the RAMBo mini as supplied by Prusa Research.
Dave what you have is nothing to do with a Prusa "original" i3 printer not Prusa Research as a company, therefore can I suggest that you go to your parts supplier and ask them for help.
Peter
Veröffentlicht : 20/07/2016 4:32 pm
