Extruder hitting bed after successful print
Rben13
(@rben13)
I just recently built my MK2. I originally had problems with getting PLA to stick, but followed a procedure that Peter posted where I used Live Z Adjust to get the nozzle within a single sheet of paper of the bed. Then the PLA stuck wonderfully and I printed the PRUSA logo. That turned out just fine. Then I decided to try 3DBenchy. The print got to about 60% and came loose, so I stopped the print by using the menu command to do so. I decided that perhaps I hadn't properly cleaned the bed, so I cleaned it with IPA and tried the Benchy print again. This time, during the calibration, on the point on the right side, half-way between the front and back, the extruder smacked into the bed hard enough to leave a substantial ding. I was alarmed and confused.
I decided that perhaps the problem was that the Z-axis had gotten out of alignment. So I tried doing Z-alignment, where the extruder is raised all the way to the top of the carriage, and one side was a little off. I raised it some more, until both sides were back in alignment, then tried calibration again.
Same problem with the extruder smacking into the bed at the same location.
I tried checking the level with my phone. (There's an app.) The bed isn't perfectly level, but it's damn close and there doesn't seem to be a lot of variation side to side. Just a tiny bit front to back.
I'm sure I've done something foolish somewhere. Please tell me what and how to fix it.
Thanks,
Ray
Publié : 07/04/2017 2:19 pm
andrey.r
(@andrey-r)
Re: Extruder hitting bed after successful print
Make sure that pinda probe is not loose. I had to use bed leveling setting on mine to "raise" one side by 50 and "lower" opposite side by 50. Also check the zip-ties that hold the bed bearings.
Publié : 07/04/2017 2:56 pm
Rben13
(@rben13)
I did check the PINDA probe, but will check it again. The bearings were one of the first things I checked. Because I have a MK2S, they are held in with U-bolts rather than zip ties. They seem to be alright, but I'll double check.
Thanks,
Ray
Publié : 07/04/2017 4:42 pm
Rben13
(@rben13)
I eventually tracked this down to the PINDA slipping. I hadn't tightened it down firmly enough.
Publié : 19/04/2017 4:01 pm
