Extruder Fan Not Automatically starting
K6TJO
(@k6tjo)
I just upgraded my Rambo Mini board from v1.0 to v1.3. Everything seems to be working but the extruder fan is not automatically starting when the tem reaches 50C. What should I do to troubleshoot this? So far all I have done is to issue M106 command which does start the fan. What would be the speed I should use for the M106 gcode? I am just using 255.
Thanks
Opublikowany : 14/12/2015 2:27 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Extruder Fan Not Automatically starting
Hi Tim
Sorry, a bit busy at the moment, so only time for a quick reply...
Firmware for RAMBo 1.3a. 1,75mm (V2.2.0)
M106 activates the part fan; the extruder fan should be automatic and is built into the firmware (Configuration.adv.h):
// Extruder cooling fans
// Configure fan pin outputs to automatically turn on/off when the associated
// extruder temperature is above/below EXTRUDER_AUTO_FAN_TEMPERATURE.
// Multiple extruders can be assigned to the same pin in which case
// the fan will turn on when any selected extruder is above the threshold.
#define EXTRUDER_0_AUTO_FAN_PIN 8
#define EXTRUDER_1_AUTO_FAN_PIN -1
#define EXTRUDER_2_AUTO_FAN_PIN -1
#define EXTRUDER_AUTO_FAN_TEMPERATURE 50
#define EXTRUDER_AUTO_FAN_SPEED 255 // == full speed
If M106 starts the extruder fan then you have the fan connected to the wrong output pins.
Peter
Opublikowany : 14/12/2015 12:37 pm
My extruder fan was wired reverse polarity!
I popped th pins out of the header and reversed them.
now Ok.
Opublikowany : 14/12/2015 7:03 pm
