Extruder fan install
joao.m
(@joao-m)
I have a doubt regarding the correct way to connect the extruder fan cables to the main board, should the extruder fan blow or extract air from the extruder chamber?
Veröffentlicht : 12/04/2016 1:39 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Extruder fan install
Hi Joao
I think the extruder fan connector is polarised? Here's the picture of the connection: https://d17kynu4zpq5hy.cloudfront.net/igi/prusa3d/SVAktpetvh4NKl2L
The extruder fan should blow air from left to right through the extruder assembly. Ensure you have the fan mounted the correct way around (label to the inside).
Peter
Veröffentlicht : 12/04/2016 1:44 pm
joao.m
(@joao-m)
Hi PJR,
Everything working fine, thank you for the help.
Veröffentlicht : 13/04/2016 12:14 am
