exact weight of an empty prusa pla-spool ?
JeffJordan
(@jeffjordan)
Member Moderator
hi guys.
now my first pla-spool that came with the i3 mk2 kit is nearly empty.
unfortunately i forgot to weigh the spool and note the weight before starting to print (which i later discovered is a very good idea).
❓ can somebody provide the exact weight for the empty spool ?
➡ so that i can weigh mine, calculate the difference and deduce if the remaining filament is sufficient for the next planned print.
thanks in advance !
Opublikowany : 29/04/2017 2:31 pm
Re: exact weight of an empty prusa pla-spool ?
Hi Jeff
My new Silver PLA weighs 1237gm including the inner vacuum seal bag
Opublikowany : 29/04/2017 3:33 pm
JeffJordan
(@jeffjordan)
Member Moderator
thanks Joan, that gives me at least a reference point.
unfortunately ... or luckily, there are often a few 10gr of filament more (rarely less) at each spool.
Opublikowany : 29/04/2017 3:52 pm
mdj
 mdj
(@mdj)
Did you eventually find out how much a spool weighs?
Opublikowany : 05/07/2017 10:40 pm
JeffJordan
(@jeffjordan)
Member Moderator
no sorry, my genuine prusa spool still has some filament left, because I've decided to print the project from the end of april with filament made by Herz.
so I meanwhile I can tell you the exact weight of the empty spools that Herz uses for their filaments (which is exactly 225 g). :mrgreen:
Opublikowany : 05/07/2017 11:04 pm
mdj
 mdj
(@mdj)
Many thanks!
Meanwhile, I unwound my Prusa (Natureworks, I guess) 1 kg black PLA spool and found that it weighs 207 g.
Best regards,
Mikael
Opublikowany : 05/07/2017 11:12 pm
JeffJordan
(@jeffjordan)
Member Moderator
...Meanwhile, I unwound my Prusa (Natureworks, I guess) 1 kg black PLA spool and found that it weighs 207 g...
thank you. that knowledge helps me (and I guess others too).
:mrgreen:
Opublikowany : 05/07/2017 11:43 pm
