Everything but the LCD Knob
michael.p20
(@michael-p20)
I recently put together my Prusa MK2s kit and have run into an issue. Everything with the LCD controller works, except for the rotary function of the knob. The knob can click, the reset button can reset, the sounds work, the SD Card reader can read, but the rotation does not work. I cannot select anything. I checked and swapped cables, both cables work fine and can be swapped and work no problem. It's only the rotation function that does not work. I have stretch out the cables and replugged them in. I have turned it off and turned it back on again. Help would be great!
Napsal : 28/06/2017 2:54 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Everything but the LCD Knob
Michael
I think you should contact support via the "Live Chat" on the shop pages and give them a link to this thread.
Peter
Napsal : 28/06/2017 9:45 am
