endstop - this ok?
Hi all. My endstops don't have the plastic tabs I see in the picks and build videos. Is this a problem? I've looked and can't find an answer or someone describing the same thing.
Thanks!
Re: endstop - this ok?
The pic... duh.
Do they trigger when the carriage / extruder hit them? If so then there is no issue.
Run "Self Test"
Thanks for the reply! I am still assembling. Just thought I would ask now in case I had to order new ones.
Hi Randy, looks like your button is the same as mine. it should be ok!
