End stop issues
nathan.e
(@nathan-e)
End stop issues
During the V2 Calibration the axis aren't hitting the end stops and just grinding. I double checked my assembly and everything looks right. On the X-axis the extruder doesn't reach all the way to the end stop.
Napsal : 06/09/2016 12:55 am
braincore
(@braincore)
Re: End stop issues
I just finished building mine, and I had this exact same problem. The X end stop would not be triggered so the extruder would continually ram the left edge. My solution was to add a couple of layers of tape to the part of the extruder that is supposed to make contact with the end stop. It works great now.
Perhaps this is due to a faulty design change rather than a lack of accuracy on the 3d printed parts?
Napsal : 06/09/2016 8:35 am
richard.c3
(@richard-c3)
Re: End stop issues
Mine did the same thing guys did you calibrate the z axis first, if the left side is too far up the end stop will not be activated.
Napsal : 06/09/2016 9:08 am
christophe.p
(@christophe-p)
Member Moderator
Re: End stop issues
Hi
When positioning the X endstop, be sure to push it on the right while tightening the screws holding it.
In addition, double check that the cable management does not touch the Z-frame.
You should be able to manually move the carriage on the left side and hear the click when the endstop is triggered.
I'm like Jon Snow, I know nothing.
Napsal : 08/09/2016 6:42 pm
Vojtěch Bubník
(@vojtech-bubnik)
Member Admin
Re: End stop issues
There is also a "Show end stops" function in the Setup menu, showing the state of the end stops.
Vojtech
Napsal : 08/09/2016 9:33 pm
