E-Axis Step 6 Screws too short
jason.l
(@jason-l)
I'm on step 6 of the 5. E-Axis step. My M3x30 screws however, are too short to go all the way through the extruder-body and screw into the motor. see images: http://imgur.com/a/KGyDC what am I doing wrong? (motor and nozzle removed for clarity)
Napsal : 24/03/2016 5:44 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: E-Axis Step 6 Screws too short
Hi Jason
Looks like you are not pushing the heads of the screws into the inset on the back of the plastic parts.
The length of the smooth/threaded section of the screws if 30mm; the width of the plastic is the same. The heads of the screws should be flush with the plastic part.
Peter
Napsal : 24/03/2016 10:04 am
PJR
 PJR
(@pjr)
Jason
Here's how the screw heads should fit:
Peter
Napsal : 24/03/2016 10:07 am
jason.l
(@jason-l)
That worked!!! Thank you!
Napsal : 24/03/2016 10:00 pm
