Drylin bearings staying Dry
murloc992
(@murloc992)
Hello,
yes, the pun in the title is intended. I am facing bad lubrication on the smoothrods with DryLin bearings. I was expecting them to be self-lubricating but from time to time I have to re-lube the smooth rods to make them move smoothly.
Is there some kind of lube I should use?
Veröffentlicht : 08/05/2017 2:26 pm
JeffJordan
(@jeffjordan)
Mitglied Moderator
Re: Drylin bearings staying Dry
did you use only DryLins at the stainless steel rods, or do you use DriveLin rods as well ?
Veröffentlicht : 08/05/2017 4:16 pm
murloc992
(@murloc992)
DryLin bearings on the original rods. The aluminum cased RJZM 8 millimeter ones. They don't have linear grooves in them, only 2 circular grooves parallel to the begin and end of the bearing.
Veröffentlicht : 08/05/2017 4:35 pm
gz1
 gz1
(@gz1)
Sounds like your rods/components are misaligned.
Also sounds like you might have compromised your bearings by putting lubrication on them.
Veröffentlicht : 08/05/2017 9:03 pm
murloc992
(@murloc992)
Everything was perfectly aligned. Without any lubrication, axis would literally get stuck. Noticed it right after assembly.
Veröffentlicht : 08/05/2017 9:10 pm
gz1
 gz1
(@gz1)
Please describe the conditions under which a bearing, which by itself probably slides easily and freely on a rod, manages to get stuck under an installed context.
Veröffentlicht : 08/05/2017 9:39 pm
murloc992
(@murloc992)
I would guess default rods and the polymer bearing might not be compatible? It is a minimal tolerance compressed aluminum encased bearing.
Veröffentlicht : 08/05/2017 10:24 pm
tim.e2
(@tim-e2)
I use also the silver Drylin bearings and teflon spray for lubrication. I use something like this: Teflon Spray (GERMAN)
And the bearings are realy smooth for mor then 200h printing time.
Regards
Tim
Veröffentlicht : 09/05/2017 8:59 am
murloc992
(@murloc992)
Thanks! I will definitely try this!
I wonder if the silicone oil and later on "high pressure bearing oil" might have ruined them..? 😳
Veröffentlicht : 09/05/2017 1:36 pm
