Clumps of Filament when printing?
Archania
(@archania)
Hi all.
Was wondering if anyone else gets like a clump of filament when printing?
I'm running a print right now and looked back and noticed that it was printing great then this:
Thinking it might be a setting to tweak for the heating of the nozzle? maybe? lol
Other then that hopefully it won't do the x axis skip today....
Also noticed that I have firmware 2.2.0. Think i need to update to 2.2.1 just in case too.
Thanks
Opublikowany : 26/12/2015 2:09 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Clumps of Filament when printing?
Hi Scott
This usually happens if the nozzle is not tight enough.
You need to heat up to temperature, leave for a couple of minutes and then tighten it up. See the "Hot-Tightening" section here: http://wiki.e3d-online.com/wiki/E3D-Lite6_Assembly
You may need to dismantle the extruder to clean out the excess leaked plastic first, although hopefully this won't be necessary.
Peter
Opublikowany : 26/12/2015 2:19 pm
Archania
(@archania)
Ah hmm missed that step! lol
Thank you very much Peter!
Opublikowany : 26/12/2015 2:26 pm
Archania
(@archania)
Gave it a twist or two.
Now printing the batman file to make sure I didn't mess anything else up while tightening the nozzle.
Edit: Well the batman printed just fine.
Now doing a 2x2 Floor Tile and seeing how that goes...
Opublikowany : 26/12/2015 3:53 pm
