Clogged again
john.f5
(@john-f5)
Clogged again
I just got my extruder unclogged, and now it is clogged again. Piece is stuck in the hotend and won't budge.
I'm going to replace my nozzle this time. Should I just heat it up and replace the nozzle, or take the whole thing apart to get the stuck bit of filament out ?
Opublikowany : 27/04/2017 5:48 am
JeffJordan
(@jeffjordan)
Member Moderator
Re: Clogged again
💡 have a look at this. tom not only gives hints about the type of nozzle to choose, he explains how to change a nozzle as well.
Opublikowany : 27/04/2017 8:27 am
OldCoder
(@oldcoder)
Re: Clogged again
Have you tried doing an 'atomic cleaning' or a 'cold pull'?
'atomic' cleaning method
https://ultimaker.com/en/resources/19510-how-to-apply-atomic-method
The Atomic Cleaning Method, and the Cold Pull
Maintaining the BB print core
https://ultimaker.com/en/resources/23132-maintaining-the-bb-print-core
Chris Shaker
Opublikowany : 27/04/2017 6:55 pm
john.f5
(@john-f5)
Re: Clogged again
Hi all, I ended up pulling the extruder out again, and replacing the nozzle. I put a steel nozzle in, and it seems to work fine.
Opublikowany : 02/05/2017 8:30 am
