Clean-> PEI Surface
SmalLabs.net
(@smallabs-net)
Clean-> PEI Surface
Hi all!
I have buy a botle of alcohol isopropyl (2-propanolo) at 99% it's right for clean my surface? 😀
Publié : 16/06/2016 8:11 pm
Patrik Rosén
(@patrik-rosen)
Re: Clean-> PEI Surface
Hi all!
Or just use some window cleaner!
Me on 3dhubs!
Me on MyMiniFactory!
Me on Instagram
3D Printing Live Feeds
Prusa MK2 Usergroup Slack Live Chat
Unofficial live chat by users for users.
Publié : 16/06/2016 8:36 pm
christophe.p
(@christophe-p)
Membre Moderator
I wonder if Methyl Alcohol could be used as well, since it's way more easy to find in local DIY stores.
I'm like Jon Snow, I know nothing.
Publié : 16/06/2016 9:14 pm
David T.
(@david-t)
I highly discourage using Methyl Alcohol. It is highly toxic and human body absorbs its vapors as good as its liquid form, and through bare skin as well.
https://en.wikipedia.org/wiki/Methanol
Just don't.
Publié : 16/06/2016 9:36 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Christophe
Isopropyl Alcohol (70% or above) from pharmacies. If you meant Methylated Spirits (denatured Alcohol) that should be OK, but can leave deposits which may cause loss of adhesion.
As far as Methanol is concerned, the amounts you would use for cleaning are quite safe - just don't drink the stuff! Then again, I seem to recall that it was added to some Austrian wines many years ago... 😉
Peter
Publié : 16/06/2016 10:48 pm
christophe.p
(@christophe-p)
Membre Moderator
Well, I agree that it's not a substance that you should deal lightly, lots of people died during prohibition because of methanol.
Such substance, as the others mentionned, needs precaution, ventilation, and wise usage for application on the surface. But some drips put on the bed and wiped with a paper towel does not give opportunity for many mg to be absorbed by the organism. Compared to acetone and isoropyl alcohol, I'm not sure that it's so different.
But I may be wrong !
But then, apart from the toxicological aspect, is it effective to remove grease from the heatbed and is it neutral for the PEI ?
Publié : 16/06/2016 10:56 pm
christophe.p
(@christophe-p)
Membre Moderator
Just missed your answer Peter.
From what I can see, depending of the country, it's more or less easy to find various substance. I know that methylated spirit for exemple is a bit diferent here from the one you can find in UK, which is not the same composition, concentration and have additive and colorant.
The English terms are a bit confusing also, so I'm trying to understand what is exactly what we call "alcool à bruler 90°". Will continue to dig, not really sure for now.
Publié : 16/06/2016 11:02 pm
PJR
 PJR
(@pjr)
Christophe
That's our "Methylated Spirits", typically used in small burners to keep food warm etc. It contains "hundreds of additives" most of which are unspecified and as I mentioned previously, some of those could prevent adhesion.
Peter
P.S. I have found the best translation of this type of term is to use Wikipedia; find what you are looking for in your own language and then change to the required language (if it is available...
Publié : 17/06/2016 7:58 am
erron.w
(@erron-w)
Ive been using the window cleaner as Josef showed in his video and have had no problem with adhesion (Good ole regular Windex Brand)
Though standard window cleaner has Ammonia in it, and i was curious if that will have any adverse affects on the PEI.
Publié : 19/06/2016 1:06 am
christophe.p
(@christophe-p)
Membre Moderator
Windex is not present in France, at least not under this brand name :/
But I tend to think that as soon as a glass cleaner is able to clean a LCD computer whithout leaving any trace (some brands do), then it should be ok 🙂
Publié : 19/06/2016 10:54 am
SmalLabs.net
(@smallabs-net)
Alcohol isopropyl (2-propanolo) work really well!! 10€ 1lt
Publié : 21/06/2016 4:19 pm
