Center of bed is closer to nozzle than the corners
SloppyPuppy
(@sloppypuppy)
This is such a weird thing...
for bed calibration I am using thin metal sheets which are very accurate. I am placing the sheet between bed and nozzle (when nozzle is homed).
I find that the center of the glass bed is much closer than the corners, either center of glass is bend upwards (impossible) or the X rods are slightly bent (possible). the difference is roughly 0.5 mm.
what should I do???
Veröffentlicht : 20/03/2016 12:32 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Center of bed is closer to nozzle than the corners
Hi SP
There's quite a few posts about this. Have a look at my post here: http://shop.prusa3d.com/forum/print-tips-slic3r-settings-kisslicer-model-repair--f12/wrong-size-of-printig-objects-t716-s20.html#p5423
Peter
Veröffentlicht : 20/03/2016 1:28 pm
