Re: Can't loosen thermistor wire on molex 3953x connector
First: this is not the thermistor wiring & connector, it's for the heater cartridge.
If you can't loosen the screws, then the wire ferrules are probably welded into the connector or the screws themselve are welded into the threads of the connector.
anyhow: the connector itself is unsafe to use any further.
my recommendation: get a new connector for your new (wired) heater cartridge.
Postato : 16/02/2018 6:34 pm
