Calibration Skewed but measured perfect?
Slash200
(@slash200)
Hello,
i measured every 10 times or more and everything is perfect. but the firmware says x/y is slightly skewed? Optical the X Axis is also perfect with the lines on the bed? Any hints for me?
Opublikowany : 02/03/2017 11:15 pm
richard.l
(@richard-l)
Member Moderator
Re: Calibration Skewed but measured perfect?
Bastian
I would just leave it at slightly skewed. I have printed with it Severely Skewed, Slightly Skewed and Perpendicular with no discernible difference in prints.
Opublikowany : 03/03/2017 3:27 pm
Slash200
(@slash200)
Hi Richard,
thanks for this information
Opublikowany : 13/03/2017 10:31 am
Wirlybird
(@wirlybird)
When my X was aligned with the lines on the bed it said it was slightly skewed. My trick is to do a "home" and see where the PINDA is compared to the circle on the bed. If it is a little toward the front of the circle then the left side of the Z frame (from front of the machine) will need to go back slightly. I repeated this until the PINDA was perfectly in the center of the circle.
Opublikowany : 13/03/2017 7:34 pm
