Cable routing around heater block - Help needed!
Hi everyone,
I need your help as I got stuck during the build.
I am currently assembling the extruder. I am at the point where the termistor and heater wire have to be put in the slit (chin) on the buttom of the x assembly block (creepy face).
For being able to put the cables to the slit I had to cut the pre-applied zip tie at the cabling. Now the cables go in the slit, but the heaterblock cables are touching the heater block. Is this a problem? What is the soultion? I cannot see a way around hit. Help (with pics) greatly needed and appreciated!!!
Thanks and best regards,
Stahlfabrik
Re: Cable routing around heater block - Help needed!
Good morning Stahlfabrik,
that shouldn't be a problem, the cables are double insulated with heat resistant sleeveing there...
I have the same problem. Has this been confirmed to not be a problem?
Thanks,
Trinity
