Build done. Trying to test print!
Hey guys.
Just got my MK2S kit put together!!
wanted to share some of the first prints. first two images are the first print. attempting the Prusa logo on the SD card. corner warped and the nozzle caught it.
second one i tried again and the corner warped even more!
so I did a Live Z adjust to .075 and am trying again! wish me luck!
Napsal : 27/05/2017 7:30 am
Re: Build done. Trying to test print!
It's much faster if you do the live Z ajdustment on the V2 configuration print. I've had to take mine down to -0,750 mm. You should get the line to stick to the bed firmly. It's much faster to do it with V2 g code than on this print. Then you just check the first layer of the Prusa logo print to see if everything is compact and sticks togheter and to the bed.
Napsal : 28/05/2017 4:18 pm
