Broken 25mm Cooling Fan Replacement
redbasi
(@redbasi)
I broke the 25mm fan used for cooling the hot end by accident (got a little bit too close and one of the blades broke). Does anybody know a good source for a replacement?
Thanks!
Opublikowany : 25/04/2016 7:39 am
christophe.p
(@christophe-p)
Member Moderator
Re: Broken 25mm Cooling Fan Replacement
Hi Basilio,
Apparently 25 mm is not very common.
First thing I would try is to contact Prusa support on the website chat, maybe they can sell you a spare (it's not on the part list on the PR website) or tell you where you could buy it ?
I'm like Jon Snow, I know nothing.
Opublikowany : 25/04/2016 12:27 pm
richard.l
(@richard-l)
Member Moderator
Actually, the replacement fan would be 30x30x10 mm in either 12v or 24v depending on your location. These are available on Amazon, e3d-online, Newegg, etc.
Opublikowany : 25/04/2016 4:32 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
It's the 12V version (irrespective of your location) available here: http://e3d-online.com/Electrical/Fans/30x30x10mm-12v-DC-Fan
Peter
Opublikowany : 25/04/2016 4:38 pm
redbasi
(@redbasi)
That makes alot more sense! I was measuring hole to hole by accident. No wonder I couldn't find anything. Thank you guys!
After looking around a bit, I found this fan: http://www.amazon.com/Gdstime-Blades-30x30x10mm-Brushless-Cooling/dp/B00MYZA6HG/
Any particular brand you guys recommend for fans that last a while?
-Basi
Opublikowany : 25/04/2016 7:16 pm
richard.l
(@richard-l)
Member Moderator
Basilio
I have 2 of those exact ones being delivered by UPS today. I have one in use now as I did the same thing you did and broke one of the fins off the supplied fan. It never hurts to have extras!
Opublikowany : 25/04/2016 8:20 pm
PJR
 PJR
(@pjr)
The only issue with those fans is the short cable, hence why I prefer to buy from the suppliers of the original equipment...
Peter
Opublikowany : 25/04/2016 9:48 pm
richard.l
(@richard-l)
Member Moderator
Peter
While I don't disagree sometimes the original supplier doesn't offer them. None listed on Prusa's site. Splicing the replacement onto the original cable is easy enough.
Opublikowany : 25/04/2016 11:04 pm
PJR
 PJR
(@pjr)
Richard
Apologies for not making myself clear in the recent post. As these fans are originally supplied by E3D, that is where I buy them and they are supplied with 1 metre leads (see my earlier post higher up...).
Peter
Opublikowany : 26/04/2016 7:27 am
Paolo
(@paolo)
Seems it is the fans day 😆
I stupidly broke mine also
Paolo
Opublikowany : 26/04/2016 2:27 pm
erron.w
(@erron-w)
Your not alone! Me too 😛 was replacing the PTFE liner, and was impatient and started removing the extruder assembly before the fan stopped spinning, of course my hex wrench hit the fan and broke a blade,
I went ahead and ordered a whole new hotend kit from Matterhackers, as i needed a new Heaterblock anyway (somehow managed to strip the threads changing a nozzle 😛 )
And the whole kit (which includes a new cooling fan) was cheaper than ordering the fan and block seperatly.
Opublikowany : 28/04/2016 6:25 pm
