Broke my thermistor... what replacement do I use?
Daniel S
(@daniel-s)
I had a accident with my brand new printer (MK2S) and a failed print covered the bottom of the hot end in plastic. While trying to get it off I broke the thermistor wire. I may have to replace the whole thing because there's still plastic all over it. Is the heater or parts of the heater standard E3D v6 stuff, or something special? I read about 30W vs 40W so I'm not sure.
Does Prusa sell parts, or should I go to an E3D dealer?
Postato : 24/09/2017 11:58 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Broke my thermistor... what replacement do I use?
Thermistor: http://shop.prusa3d.com/en/mk2-spare-parts/139-mk2-heatbed-thermistor.html
If you don't have access, ask "Live Chat" to let you view the spares.
The heater is the 40W (I believe - check the wire colour): http://shop.prusa3d.com/en/mk2-spare-parts/122-e3d-40w-heater-cartridge.html
Or you can buy from an E3D reseller near you.
Peter
Postato : 25/09/2017 9:57 am
