Bridging Test, eSun PETG
Carsten
(@carsten-2)
Who could know that it worked out so good with no tweaking. And also produces such a nice object 😮 😯 😆
Biggest Bridge is 5cm. Not sure if one can expect more without optimizing? What is the key? I am not sure if I should speed the bridges up or use less extrusion? Maybe I just wait for a real world bridge in an object before taking the time to optimize.
Carsten
My Prints: https://www.prusaprinters.org/social/15695-carsten/prints
My Employer: https://make-magazin.de
Publié : 07/12/2016 11:43 pm
gz1
 gz1
(@gz1)
Re: Bridging Test, eSun PETG
In my opinion PETG is hard to bridge with because it's less rigid and doesn't shrink.
A material like PLA bridges nicely because it's pretty rigid as it comes out, and when you tack it off to the other side, it shrinks a little and helps tighten things up.
That said, in your example, your failure is that the bridging wasn't recognized by the slicer. The original perimeters were bridged, but then it went to infill and it turned into a mess.
The fix to try for that is to increase your perimeters. Basically make every one of those bridges all perimeters so it shoots straight across.
Publié : 08/12/2016 4:26 am
Carsten
(@carsten-2)
Fail? Only the longest two have some stings falling trough?
And I can easy see while printing that PETG is shrinking. The perimeter hangs a bit after pulling and then cooled it lifts up nicely.
Carsten
Publié : 08/12/2016 12:54 pm
gz1
 gz1
(@gz1)
Uh, well, I wouldn't exactly call it a success. Like if that were a customer print, I wouldn't give it to him and exclaim, "The print was a success!"
PETG shrinks a little, but not nearly as much as PLA.
Oddly, that property means PETG is better at overhangs and worse at bridges.
And then PLA is better at bridges and worse at overhangs (because the shrinkage causes the overhangs to curl up).
Publié : 09/12/2016 9:48 am
Carsten
(@carsten-2)
For a customer i would print with Support and .2 layers.
Carsten
Publié : 20/12/2016 11:48 am
