Bridge help needed in KISSlicer
Página 2 / 2
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Bridge help needed in KISSlicer
Look on the "Support" tab, top right.
The pillar is just a thin-wall cylinder used to prime the extruder at the start of each layer; it can also be used to effectively slow the layer down while the plastic cools.
Try turning it on, slicing a model and the selecting Models+Paths; move the thumb up and down, you will see that is generated.
Peter
Respondido : 03/01/2016 5:15 pm
Jason
(@jason-26)
Thanks!
Respondido : 03/01/2016 6:03 pm
Página 2 / 2
