Blocked extruder
Blocked extruder:
After a series of print tests with the material you supplied with the printer, now I'm with the blocked extruder. What should I do?
Publié : 06/06/2017 8:52 am
Re: Blocked extruder
Blocked extruder:
Mind being more specific? How do you know the extruder is "blocked" or clogged? Can you list the symptoms you have observed? Is there a clicking sound coming from the extruder area? Have you tried to unload and reload the filament (recommend cutting the tip at an angle)?
Philip G.
Original Prusa i3 MK2S
Turnigy Fabrikator Mini
Publié : 06/06/2017 7:37 pm
