[Closed] Bent X rails, bed not leveling
Joe McLoughlin
(@joe-mcloughlin)
I have received and assembled the printer kit that I have received about two weeks ago, but I have encountered a problem with the x rails bending downwards and giving me layer shifts as well as problems with the crash noise when it tries to auto-level at the beginning of a print.
I am using the 7x7 grid instead of the default grid of 3x3 but when I change the grid back to the 3x3, it still encounters the same problem.
The nozzle is not rubbing on the bed, and my build surface is not warped.
Napsal : 20/11/2019 9:42 pm
RE: Bent X rails, bed not leveling
Contact Prusa support using the store CHAT button.  They will help you figure out what is wrong with the printer.
I say this because your problem description defies logic and defies what the printer can do: e.g., the printer has no way of bending the X axis rods downward.  Where's the force coming from to do that??
And, assembly problems usually cause shifts, so something is too tight: or bearings weren't lubricated before assembly, etc.
And - without photos to show what the issues are - well - everything will be a total guess.
ps: grinding noises are normal during a HOME operation.  So how long it grinds, where it grinds, all are pertinent to the diagnosis.
This post was modified před 6 years 2 times by --
Napsal : 21/11/2019 12:11 am
rmm200
(@rmm200)
Like Tim said - it is not possible to bend the frame members, and there is no force on the rails to make them bend.
Does your printer pass self test?
If you calibrated Z after that, post a picture of the result. Preferably use a calibration circle; not the built-in one.
And don't just hop in and try printing multi-layer objects before you have the basics down. You will just frustrate yourself.
Napsal : 21/11/2019 12:53 am
