Belt twist - cause?
I'm seeing a bit of a belt twist and am unsure of the cause.
I have filmed it and have uploaded the video to youtube
and suggestions of how to fix? i assume its an issue
Could it be causing my shift left when printing thin columns?
Opublikowany : 08/12/2017 11:26 pm
Re: Belt twist - cause?
If you search "belt twist" in the forum, you would find this link:
https://shop.prusa3d.com/forum/original-prusa-i3-mk2-f23/belt-rubbing-on-x-axis-t1232.html
Opublikowany : 09/12/2017 3:11 am
Mine does this but prints superbly so I ignore it.
My printer is 10 months old and had a fair bit of use.
Opublikowany : 25/12/2017 8:55 pm
