Bed fasteners not lined up
Tomkat2244
(@tomkat2244)
I just received my MK2 upgrade kit. After I assembled it and was testing the printing I noticed that the print would not stick to the bed. After cleaning it and trying again it still failed. Upon closer inspection I realized that the screws on the y axis belt tension block were not screwed into the stand offs under the heat bed. I backed them out thinking they would align and screw in properly but this was not the case. I turns out that my stand offs do not all six align together. The four outer ones align fine but then the center ones do not, and if I align the center ones the outer ones are out of alignment. I "fixed" this by finding shorter screws that did not go all the way through the frame so the middle stand offs are sitting on the frame without being screwed on.
I am printing fine now, I just wanted to post this to see what people have to say. Thanks.
Postato : 10/07/2016 11:45 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Bed fasteners not lined up
Rickey
Do you have the center belt fixing the correct way around? It is quite easy to get it reversed. Either that or your Y belt alignment os off to one side.
Peter
Postato : 11/07/2016 10:15 am
