Backup/Upgraded Extruder
cory.w
(@cory-w)
Hey Everyone,
The hotend thermisistor on my MKS2 appears to have the wires looking really fragile which I have seen recent complaints of. I am thinking of ordering a spare extruder assembly to either pick parts from or switch out entirely if/as needed.
Are there any other models that perform better I should just switch to instead? What are the benefits?
Thanks!
Opublikowany : 21/05/2017 11:11 pm
cory.w
(@cory-w)
Re: Backup/Upgraded Hotend
I should update this and say I am actually looking for a hotend assembly 😛
Opublikowany : 22/05/2017 5:40 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Backup/Upgraded Extruder
Cory
You won't find much better that what is already installed: http://e3d-online.com/E3D-v6/Full-Kit/v6-1.75mm-Universal
Peter
Opublikowany : 22/05/2017 5:51 pm
cory.w
(@cory-w)
Thanks PJR!
I just ordered the screw in thermistor from RepRap which had good reviews and got some new PEFT.
I read someone recommending putting a cone shape on the PEFT on the end that goes to the hotend I believe? They suggested using a pencil sharpener. Not sure how much to do. Also nipping the other end by the extruder a certain way. Anyone have pictures of this?
Opublikowany : 22/05/2017 8:25 pm
PJR
 PJR
(@pjr)
Not all thermistors are the same. In fact most will not work with the default firmware. You need to ensure that what you ordered is a Semitec 104GT. All others (if they are supported) require a firmware change.
... got some new PEFT.
That would be PTFE tubing then... Yes the lower end needs to be bevelled to match the heat break; a pencil sharpener, although not ideal can be used for this. The top end may be opened out a little should you so desire but for single filament printers, it is not necessary.
Peter
Opublikowany : 22/05/2017 10:08 pm
cory.w
(@cory-w)
Thanks for the heads up. Grabbed the wrong style thermisisor originally but found the same style in the right type.
https://reprapchampion.com/collections/new/products/high-temperature-300c-screw-in-hex-thermistor-for-3d-printer-extruder-hotend
Opublikowany : 22/05/2017 10:16 pm
PJR
 PJR
(@pjr)
Not sure if that will fit in place.
They are showing a picture of the old style E3D heater block with the thermistor screwed into the threaded hole used to hold the thermistor in place.
The new block has a larger unthreaded hole with a grub screw from below holding the thermistor casing.
This is what you need: http://e3d-online.com/Thermistor-Cartridge?search=thermistor for the current heater block
Peter
Opublikowany : 23/05/2017 11:23 am
