Any idea what i need to adjust here?
CoyDK
(@coydk)
I have had allot of calibration issues, I have fixed most but any one got an idea how to fix this?
Postato : 02/08/2016 3:47 pm
David T.
(@david-t)
Re: Any idea what i need to adjust here?
Adjust Z a bit down.
What do you use for cleaning the bed?
Postato : 02/08/2016 6:13 pm
CoyDK
(@coydk)
I use alcogel and Window cleaner.
Postato : 02/08/2016 6:33 pm
CoyDK
(@coydk)
I am using Slic3r. Just to be sure the "print setting" need to be on 0.20mm NORMAL right? I am running 1.75mm PLA if thats any help
Postato : 02/08/2016 6:35 pm
David T.
(@david-t)
Some window cleaners cause the filament doesn't stick to bed. Try clean IPA for a few prints.
Postato : 02/08/2016 6:46 pm
CoyDK
(@coydk)
Thanks I will try that 🙂
Postato : 02/08/2016 6:52 pm
CoyDK
(@coydk)
Each time I run the X/Y calibration I get the "X/Y Skewed severely. Skew will be corrected automatically"
Postato : 03/08/2016 10:12 am
Kaizers808
(@kaizers808)
Jakob, the x/y skew shouldn't affect the adhesion of the 1st layer, because FW 3.0.6rc2 automatically corrects the distortion as your message states.
I have had the same layer bubbles from time to time, and typically what helps is:
1. I raise my Z-height 0.025-050mm.
2. Increase the flow rate on the lcd Menu -> Settings -> Tune -> Flow. I would raise it 10-15%. After the 1st layer is finished drop it back down to 100%. Alternatively in your slicer settings you can just increase the 1st layer height or flow in your slicer settings as well. I like to do it on the machine directly because I can instantly see if increasing the flow helps or not, instead of wasting a whole print.
3. Use the glue stick.
Remember to make 1 adjustment at a time to see which one worked lol.
Good luck!
~Kaizers
Postato : 03/08/2016 11:03 am
Vojtěch Bubník
(@vojtech-bubnik)
Utenti Admin
Jakob,
we are filling up a knowledge base. Your question on the XY calibration "axes severly skewed" shall be answered here:
http://help.prusa3d.com/mk2-movement-calibration/calibrate-x-y-info-and-errors
Vojtech
Postato : 03/08/2016 6:02 pm
CoyDK
(@coydk)
Vojtech you are a champ!
Thanks!
Postato : 05/08/2016 4:37 pm
