Accessing stepper signal from Rambo board
3D Print Singapore
(@3d-print-singapore)
Is there a way to neatly access the Step/Direction/Enable signal from the rambo board ? some kind of connector ?
I am planning to use Mechaduino on my prusa mk2
https://www.kickstarter.com/projects/tropicallabs/mechaduino-powerful-open-source-industrial-servo-m/description
I hope it is not soldering some point to point connection to the SMD components.
Opublikowany : 28/09/2016 8:40 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Accessing stepper signal from Rambo board
They are apparently "drop in compatible" so you won't need to worry about the generated signals.
Peter
Opublikowany : 28/09/2016 8:47 pm
3D Print Singapore
Unfortunately,Rambo board does not have access connector link to Dir and Step pins of the arduino. Hence, for anyone to use the mechaduino, he/she must do a point to point solder to access the signals.
Opublikowany : 30/09/2016 9:24 am
walker.e
(@walker-e)
I'm looking to do the same ...
The schematic of the rambo are available, we will need to do some precision soldering job ...
Opublikowany : 06/10/2016 9:45 am
