Acceleration Jerk
maurizio.l
(@maurizio-l)
Acceleration Jerk
Hey,
I'm having an issue with super tiny ripples over the whole print (not just corners everywhere) so I thought I'd check my acceleration and jerk settings:
echo:Maximum Acceleration (mm/s2):
echo: M201 X9000 Y9000 Z500 E10000
echo:Acceleration: S=acceleration, T=retract acceleration
echo: M204 S1500.00 T1500.00
echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
echo: M205 S0.00 T0.00 B20000 X10.00 Y10.00 Z0.20 E2.50
Aren't these a little on the very high side? :O Most of all since I can't manually change my acceleration settings in s3d.
Respondido : 17/07/2017 2:15 am
AJS
 AJS
(@ajs)
Re: Acceleration Jerk
Those are higher than the settings in Slic3r (Prusa defaults). which has accelerations from 800-1000 for visible layers and 2000 for infill.
Respondido : 17/07/2017 4:14 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Simply add the following line to the start G-Code:
M201 X1500 Y1500 E600 ; set default acceleration
Peter
Respondido : 17/07/2017 1:12 pm
