ABS prints not doing well as they get higher
First my pla prints came out great! Also my Prusa lettering in ABS came at good too, but then I went to print something taller and it seems to mess up. I have tried temperatures from 210-255 with all the same result.
PLA prints
ABS prints
Any suggestions? Also, how tight should the extruder screws be? The ones with coils? Thanks.
Napsal : 11/09/2015 5:46 am
Re: ABS prints not doing well as they get higher
That's overheating. You can adjust the cooling in Slic3rs filament tab. Unfortunately, when you start to cool the abs more, those little pins will look as well as with PLA, but would be extremely brittle :-/
Best solution for ABS is to print multiples of the object, so layers have time to coool down 💡
Founder and owner / Majitel a zakladatel
Napsal : 11/09/2015 2:52 pm
on such prints I reduce speed for the top part down to 50 - 20%
Napsal : 14/09/2015 8:15 pm
