ABS brim pulled top layer of bed
andreas.j
(@andreas-j)
Hey forum,
today I printed some small parts in ABS with a 5mm brim at bed temp of 90°C.
After colling it down I removed the parts from the bed and then the brim. When cleaning the bed I felt it was uneven.
It looks as of the warping of the parts pulled the top layer plastic sheet partly of the heatbed.
When I look at it from the side I can see it is uneven now and I can feel it with the finger when I go over it.
Is there a way to solve this problem? I tried heating the bed up again but the sheet will not "lay down" again.
Any help is appreciated.
Opublikowany : 30/10/2017 10:25 pm
JeffJordan
(@jeffjordan)
Member Moderator
Re: ABS brim pulled top layer of bed
➡ this does not only happen with abs, it happens with other filaments as well.
💡 it's quite normal and related to the glue underneath the pei sheet.
stay calm.
the unevenness of the pei sheet will vanish after a few days & prints.
Opublikowany : 31/10/2017 12:13 am
