50 micron problem
Xebrecito
(@xebrecito)
50 micron problem
hi guys
i am using slic3r that comes with the drivers with prusa presets.
the filament is pla from bq at 210º and the bed at 55º
left one 50µm the right one 200µm
i also printed the frog that comes with the sd in 50µm and quality is worse than the 50µm marvin
at the same time a benchy printed to 200µm has good quality
any idea ?
Posted : 04/10/2016 2:01 am
Xebrecito
(@xebrecito)
Re: 50 micron problem
from left to the right 200µm 100µm 50µm
Posted : 04/10/2016 2:56 am
Patrik Rosén
(@patrik-rosen)
Your 0,2mm version doesnt look good either, try to get that one perfect first before testing 0.1 and 0.05 (you will probably never need to use 0.05 btw, a well tuned printer prints 0.2 and 0.1 with really good quality
Could you give us more info? Fan on/off? Speed?
Me on 3dhubs!
Posted : 04/10/2016 11:08 am
Xebrecito
(@xebrecito)
fan on.
the speeds the default in slic3r with prusa settings.
benchy or the vase from the sd are printed fine.
Posted : 04/10/2016 4:25 pm
