50 micron prints look bad
murloc992
(@murloc992)
Hello,
I have been trying to pull off some 50 micron prints but I seem to hit some intense ghosting for no reason..
Prints are: 200 micron, 100 micron, 50 micron.
My Live-Z is -0.700mm, I lifted it a bit from -0.750mm but it didn't change much.
Weirdly, only the 200 micron print looks best..
The filament is Colorfabb NGEN PET.
Postato : 27/05/2017 11:29 pm
henrik.w
(@henrik-w)
Re: 50 micron prints look bad
Hello Murloc992!
Have you tried variable layer height in the Prusa Edition of Slic3r? That may accomplish relly good result faster.
/Henrik
Postato : 03/09/2017 12:58 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
50 micron is really pushing the printer just a little bit too far.
In order to get a constant extruder pressure, you need to print quickly, but that brings other issues to the table.
The MMU has a minimum layer height limit of 70 microns, due to the lower number of steps/mm, but I print minimum of 75 microns and I am very happy with the quality of that. Can I suggest that you try 75 microns - I think you will be satisfied.
Peter
Postato : 03/09/2017 1:58 pm
