XY shifting in different Z-hights
Ragnar
(@ragnar)
Hey together,
currently I'm modelling a Lego Duplo compatible brick and there is that issue I allready had a few times with other prints.
The outer wall which is supposed to be straight up starts to shift a bit inwards in the moment when there is a change in the inside geometries. I wonder if this is just because of the min. line width which I maybe could compensate with a thicker wall or if this is some printer setting issue.
Please have a look at the attached pictures.
I'd be super happy for any advice!
Thanks, André
Opublikowany : 24/03/2018 2:53 pm
MechLink
(@mechlink)
Re: XY shifting in different Z-hights
Try checking your belt tension and running the "Self Test" and you can check to see if any of the bolts are loose on the machine especially with the X-Y axis.
If its not mechanical it could be settings on the print such as not running "High Power mode", if you are using "Linear Advance" try it with it off, ETC.
try running basic settings and see if it changes, its kinda trial and error to narrow it down and see what can cause it.
See my stuff at
https://www.printables.com/@MechLink
https://www.myminifactory.com/users/MechLink
Opublikowany : 24/03/2018 5:48 pm
