What's MK3 best overhang angle?
janis.j
(@janis-j)
S3D default setting is 45, but has anyone printedPLA with shallower angles successfully?
Opublikowany : 12/01/2017 2:41 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: What's MK3 best overhang angle?
Janis
I have printed at 70 degrees from vertical without supports, but it does rather depend on the model and other settings (Loops before perimeters etc).
Peter
Opublikowany : 12/01/2017 3:52 pm
Vojtěch Bubník
(@vojtech-bubnik)
Member Admin
Slic3r has a unique "use bridging perimeters" feature, which extrudes thicker extrusion width on slopes, where the perimeters overlap less than 1/2 of their width. This allows one to print slopes as high as 70 degrees quite reliably.
Opublikowany : 12/01/2017 6:31 pm
janis.j
(@janis-j)
Many thanks!
Opublikowany : 13/01/2017 9:34 am
Damn, I have missed a release...
My new Mk2 hasn't been shipped yet, do you think I can get the order changed to a Mk3 ?
Joan
Opublikowany : 13/01/2017 5:55 pm
