This user asks for help regarding the Surface of a Print in the Prusa Forum. You wont believe what happens next!
philip.z
(@philip-z)
Sorry for my ... uuuhm "creative" title.
I am having issues with shifted/visible layers. Any Help would be appreciated!
Some information:
Images: https://imgur.com/a/AfiRG
Filament diameter is consistent
Temps: 200-230 happens at all temps
Belts: Tightened
Material: PLA
Napsal : 17/02/2017 7:21 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: This user asks for help regarding the Surface of a Print in the Prusa Forum. You wont believe what happens next!
Humm. What does happen next?
I see some banding on the layers which has a few causes:
Build quality (belts not tight/over-tight
Pulleys not tight
Inconsistent filament feed (from spool onwards)
Extruder pulley not tight/dirty
Poor quality filament
Partial nozzle/PTFE blockage
Excessive retraction
Z Axis not moving freely (if using Z-lift)
Bad slicing parameters.
Plus others that won't come to mind at present.
Go back to basics and print a model from the SD card; doing that will eliminate a few potential problem sources.
Peter
Napsal : 17/02/2017 4:15 pm
Carsten
(@carsten-2)
I have seem this just last week. Is that part hollow (only shell)?
I found that printing as solid (infill (no matter whch one)) fixed it. The real cause in my case was that I scaled the modell quite a lot up and down during preparing it in my CAD and so I think there was also a precision problem, causing the slic3r to get confused and having the perimeters flap a bit in the breeze. The slicer tried to reach the exact wall thickness with two perimeters and altered the extrusion etc. which worked not well...
Carsten
My Prints: https://www.prusaprinters.org/social/15695-carsten/prints
My Employer: https://make-magazin.de
Napsal : 20/02/2017 12:41 pm
philip.z
(@philip-z)
Thank you for the answers! The Issue was a missing nut on the pinda probe. I found the nut 2 weeks ago and didnt think much about it. Until i noticed that it was missing at the bottom of the probe. Prints are nice and smooth again.
Napsal : 22/02/2017 1:16 pm
