Tale of 2 prints
K6TJO
(@k6tjo)
Tale of 2 prints
Hi ,
I have printed two funnel shapes. The first (smaller) one came out pretty well but the second one (larger) had a real rough finish.
The folder I have shared contains the images as well as the Slic3r settings files. The big differences between the print is that on the larger funnel wall thickness was reduced from 3mm to 2.5mm and the Fill Pattern was changed to Octagram Spiral and the Top/Bottom fill to Rectilinear.
http://1drv.ms/1NVSYnL
If you have any suggestions on why the finish came out so bumpy and odd I would love to hear back.
Thank you!
Opublikowany : 09/07/2015 4:38 pm
pietro.g
(@pietro-g)
Re: Tale of 2 prints
Wow that first one looks way better than the second. I wonder if it was the fill pattern because the top/bottom fill as rectilinear is set as default for me.
Opublikowany : 09/07/2015 5:29 pm
Josef Průša
(@josef-prusa)
Member Admin
Thin walls can sometime cause this, it works best if the wall is 4 times the line width or more.
Founder and owner / Majitel a zakladatel
Opublikowany : 13/07/2015 11:56 am
